Power antenna
Power antenna
The antenna of my 1997 850 sedan stopped working. It had been mess up by the previous owner. The plug from the radio has 3 wires But the plug from the antenna has 2 wires connected and 1 wire open. Is it normal? Can I replace it with an aftermarket one. I found the Pyle antennafrom buy.comecosts only 29.99.
RE: Power antenna
The motor is not working. The plug from the antenna seems to have 3 wires I guess. Now one wire is cut and left open connecting to nowhere.
IfI buy an OEM antenna, this plug will be taken care. If I buy a aftermarket antenna (that is 1/10 of the cost of the OEM one) I will reuse this plug. Can someone tell me what are these 3 wires?
RE: Power antenna
Check the fuse just for the heck of it.See attached pics.
The manual indicates '96, but I believe the '97 model is the same.
If you only need to replace the mast, see if you can call either FCP Groton or eEuroparts to see if they have the EXACT match for '97. Since Jim had a bad luck at FCP Groton (they are usually good but the shipping dept might have screwed up), I'll only list the URL for eEuro:
http://www.eeuroparts.com/searchresu...8&cat=1002
And shame on your friend[8D].
JPN
[IMG]local://upfiles/6892/8DC939B3CBBC4B98BCEEFA4BD687EB3E.jpg[/IMG]
[IMG]local://upfiles/6892/E6F1D246039C41F6B597FDAB682462A3.jpg[/IMG]
[IMG]local://upfiles/6892/D5F935C9CD7A4348A6AEAF76FDF28EFC.jpg[/IMG]
JPN
RE: Power antenna
When they sent me the wrong one we tried to get it to work and that's when WE mess up the setup to where the correct mast would not even fit. When I called fcpgroton to tell them they sent me the correct mast at no charge and appologized. Somebody had put the wrong ones in the bag. Now I have the mast, but I did buy a whole new antanea on e-bay from Volvo of Orange County for $92.00.Their phone number is 1-866-414-0242. It's an oem antenae.
bsobo
04-20-2010 08:18 PM
