11-16-2009, 11:13 PM
Replacing Catalytic Converters on a 1996 Volvo 850 Turbo
I need to replace the Catalytic Converter on my car. I am thinking of buying the converter that can be welded to the existing pipe.
There is the option to buy the converter with the upstream and downstream pipe. This is of course expensive - about $350-400.
Any suggestions?
I would like to know how easy or difficult it is weld the catalytic converter. Does this require disconnecting the pipe from the turbo? Is it reliable?
11-17-2009, 12:38 AM
if you can't weld then take it to a local shop that will work with cats. some shops wont though. It is safe and reliable.
11-17-2009, 06:45 AM
I don't know if you have the existing pipe or not, but when I replaced my exhaust, my stock exhaust was severely rusted, it might not be a bad idea to get a look at the whole thing and see what kid of shape its in. FCP sells the downpipe with cat for 300 bucks, and the cat back for 240. Just an idea.
11-17-2009, 09:23 AM
Platinum Sponsor
+1
It may end up costing you more in the long run to have it welded, especially if the exhaust is very old.
11-17-2009, 11:55 AM
I have one for sale...Conical flanged from a 95 T-5R
__________________
Built B5234T5, H-Beams, ported, N/A cams, Cyro'ed, 20G w/ARD Black tune at 20psi, Greens, R-Mani, Meth injected, 3" exhaust, catless, M56L, Quaife, R-Clutch (Cyro'ed), FMIC, Snabb intake & hoses & Poly, HKS Blow-off, ARD pulley, Bilstein shocks, H&R springs, IPD sways, MSD+6A and 5 spark plugs.
342whp/403bhp
13.8@103 Manual 18T
13.7@99 Automagic 18T
11-17-2009, 09:30 PM
Quote:
you mean you have a downpipe forsale with scrap metal attached to it
11-17-2009, 09:44 PM
Call it what you want but I have a fully functional downpipe attached to a factory OEM Cat in great condition for sale.
But i know what you mean....I wish all these California laws were not in place, I would remove mine.
__________________
342whp/403bhp
13.8@103 Manual 18T
11-17-2009, 11:08 PM
It's actually against federal law- not just california law- to sell a used cat for reuse. That's why you're selling a used downpipe with a piece of scrap metal on it
Keep in mind... New aftermarket converters are NEVER as good as originals... they have less catalyst in them, so they won't last as long... it's an exception the government made to make aftermarket converters more affordable, so that people would replace them. A large factory converter can have as much as $500... or more... worth of platinum and rhodium in them. And when you take your original converter out, make sure to take it to a scrap metal yard... they're actually worth a pretty good bit of money.
__________________
'98 Volvo S70 GLT-170k miles- my everyday driver. Mods: 16T turbo, injectors, ECU, TCU, wheels, and interior trim from a T5.
'02 Volvo XC70-130k miles- Wife's car
'95 Volvo 850 T-5R  Black. Rescued from oblivion, needs help, am now providing said help.
'93 Volvo 940 Turbo wagon, 141k miles- Workhorse/ toolbox.
'88 Mercedes 190E 2.3- bought to fix up and sell, but I kinda like the little old beast, so I'm holding on to it for a little while.
11-18-2009, 01:15 AM
Thanks for all the tips. I searched on Ebay and found one. It has 3 O2 sensor ports. My 850 has only 2 ports. What's with the additonal port?
http://cgi.ebay.com/ebaymotors/93-94...Q5fAccessories
11-18-2009, 06:26 AM
So you can run a wideband AFR!
Tags
1996, 850, bad, broken, buy, catalitic, catalytic, converter, convertor, exhaust, replacing, s40, stock, t5, turbo, volvo, welding  |
| Thread Tools |
Search this Thread |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
