Transmission Problem
Old 06-22-2013, 10:16 AM
Desmond Chong's Avatar
Default Transmission Problem
Hi
I am a proud owner of a Volvo 850 GLT 2.5 that have a problem of my auto transmission.
The problem is the gear will not change for gear 1st to gear 2nd during cold.
After the transmission warmed, it will have not problem with gear changing at any speed.
Please advise what could be the problem.
Thanks a lot for you help.
Old 06-22-2013, 02:05 PM
go-part's Avatar
Former Sponsor
Have you checked the condition and level of the transmission fluid?
Old 06-22-2013, 02:12 PM
What year is it ??
Have you followed the Volvo procedure for checking fluid level ??
What color does the fluid look ??
Do you have a check engine light on, a flashing arrow ??
Old 06-23-2013, 09:26 AM
My Volvo 850GLT is year 1994.
The transmission level is filled to the fill mark.
The fluid is red in colour.
Old 06-23-2013, 09:27 AM
There is not flashing arrow sign at all
Old 06-23-2013, 10:47 AM
slimflex2's Avatar
if there isnt a flashing light,may be you need to do a ATF change. make sure the flashing arrow dash light works. turn on the ignition, do not start the car, make sure you see an arrow light up on the dash. l think its between the check engine light and SRS. am not sure. but check for that and make sure nobody removed the flashing arrow dash bulb.
Old 06-23-2013, 01:29 PM
Are you sure you checked the fluid level properly? Was the car running and the tranny hot?
Old 06-23-2013, 01:34 PM
To check the bulb, look at this video which should start at 1 minute. The arrow in the corner is the light that should work for you.
Old 06-23-2013, 01:35 PM
Since you have a '94, your OBD-I port under the hood will have any transmission errors stored in it. I'll post a video on how to check the port later today for you.
Old 06-24-2013, 06:57 PM
The fluid level is good and red in colour. Mileage only 100,000km. Will waiting for your video.
Old 06-24-2013, 09:23 PM
Here you go man. Check the A1 port, then the A5 port. Then post the codes here.
Old 07-01-2013, 08:54 AM
There is no fault on the transmission code. Please advise what could be the problem.
Old 07-01-2013, 12:43 PM
Most transmission shops offer a free diagnosis / test drive. You might want to take a couple up on the offer and see what they have to say. I'd call and ask if the work on your year, make and model before stopping in though. It's best to have someone who works on them do the diag as they would be more likely to know what's going on inside.
mason3325
12-22-2021 12:51 PM
jeffrisley
06-14-2015 01:48 PM
roughyear
01-02-2005 12:12 PM
Quick Reply: Transmission Problem
