Fan Relay Plug Removal
Old 06-28-2016, 02:17 AM
Luke Woessner's Avatar
Exclamation Fan Relay Plug Removal
The middle plug (in) on my radiator fan relay refuses to come free from the relay. Is there any release tab or something holding it in other than the big obvious one? Thanks for any input!
Attached Thumbnails Fan Relay Plug Removal-img_20160619_145024.jpg   Fan Relay Plug Removal-img_20160619_145032.jpg
Old 06-28-2016, 10:36 AM
tryingbe's Avatar
Do you have silicone spray? Do you have set of pliers?
Old 06-28-2016, 03:29 PM
Yes to both. Just douse it in silicone WD-40 and pull with pliers?
Old 06-29-2016, 12:22 PM
Ozark Lee's Avatar
Pull the release tab back with your thumb and then wiggle the connector. I find it to be much easier to remove the connectors after the relay has been removed. The relay slides out by pulling it back toward the engine. There is a tab molded into the fan shroud that keeps it in place but a good yank will get the relay past that tab.
...Lee
Old 07-02-2016, 08:03 PM
Thanks for the tip! A few liberal applications of silicone WD-40 and some pliers got it right out.
Volvo_Oz
07-31-2022 08:26 PM
sleech
01-25-2020 05:07 PM
Luke Woessner
06-20-2016 11:15 AM
dads 740 turbo
10-24-2008 06:54 PM
tmor84
10-10-2006 10:54 PM
Quick Reply: Fan Relay Plug Removal
