reset SRS light
Old 12-08-2007, 12:52 AM
MSP850T's Avatar
Default reset SRS light
I replaced my speedometer with a used one, and now the SRS light will not go out.I know about the reset light, and i did have to repair the steering wheel horn connection, so could either of these items be my problem?
The codes usually clear this don't they?
Thanks,
MO
Old 12-08-2007, 07:05 AM
JimKW's Avatar
Default RE: reset SRS light
To reset the SRS light requres a trip to the dealer. They charged me $117 just to reset that light when I had another guy do my evaporator and fixed something in the steering column causing the SRS light to come on. It ticked him off that he could not reset the SRS light and had to go to the dealer and could not believe how much they charged him.
Old 12-08-2007, 07:45 AM
JPN's Avatar
JPN
JPN is offline
If your 850 is of '93-'95, you can reset the SRS light manually via OBD-I. However, for '96 & '97, you'd have to visit a dealer and donate $$$ as Jim has already stated.
Let us know the model year of your 850. If it is '93-'95, I can give you instructions.
JPN
Old 12-08-2007, 12:25 PM
mines a 95 i need to reset my srs light too
if you could post instructions that would be awesome
Old 12-08-2007, 04:10 PM
http://www.troublecodes.net/Volvo/
SRS is B5
Old 12-10-2007, 12:25 PM
MSP850T's Avatar
It is a 94 automatic turbo wagon...
Old 12-11-2007, 05:49 AM
JPN's Avatar
JPN
JPN is offline
Here are the instructions. See attached pics.
In case if you still have the SRS warning even after clearing codes and the ECU only shows 111, I'll supply with additional info.
JPN
[IMG]local://upfiles/6892/766EDA9E9DFA49388E2ED4CA4EEADC81.jpg[/IMG]
[IMG]local://upfiles/6892/EACFE4E6F4AF4DD5A53F2A8856F96D7A.jpg[/IMG]
Old 12-11-2007, 09:28 AM
To clarify. . .
Even though a 94 Auto Torbo Wagon has an ODB-II port the SRS light can still be cleared via the OBD-I port?
Thanks
Old 12-11-2007, 05:31 PM
Yes it can the OBDII wouldn't read SRS anyway.
The OBDII will only read engine codes.
Old 11-24-2008, 10:55 AM
deary5280's Avatar
Is there a way to troubleshoot and reset my SRS light on my 98 V70?
Old 01-13-2009, 04:45 PM
slade8200's Avatar
When I put the connector in B5, the light comes on as soon as the connector is placed in. Pressing the button for any amount of time does nothing. Has anyone had this issue?
Old 01-13-2009, 05:12 PM
Maybe try disconnecting the battery and leave it for a little while and see if that resets the computer.
Make sure you have your radio code before disconnecting the battery
Old 11-05-2009, 08:14 AM
RedVol's Avatar
Where are these instructions that JPN posted? Thanks!
Old 11-05-2009, 06:59 PM
mhutchens's Avatar
The document located here: http://www.volvoclub.org.uk/tech/ser...aintSystem.pdf
Has all the information you could want for the 850 '93-95 SRS system. It explaines why different codes set, how to test and how to reset. If I remember rights after clearing the code you have enter a code to put the system inself test, just like the ABS system.
These instructions worked forme when my SRS light came on after driving without my passanger side air bag (pulled the dash pad out to try to fix it).
Old 11-07-2009, 11:01 AM
s_moneh's Avatar
would u fail a safety inspection if the SRS light is shown??
sadly enough i unplugged my passenger airbag and nwo the SRS light is on (n)
Old 11-08-2009, 04:31 PM
s_moneh's Avatar
will it? :S
  #17
Old 01-13-2011, 05:58 PM
jeanmaryr's Avatar
Default reset 94 850 turbo srs lite
JPN
Would it be possible to access these images and instructions?
  #18
Old 02-01-2011, 07:32 PM
RedVol's Avatar
(n)
That depends on your state's law.
One devious way around it is to pull out the bulb for the SRS light on the dash. That way the indicator is not lighted.
My experience has been that the computer diagnostics that are used by shops in doing safety inspections also cannot tell whether the SRS code has been activated. So, if there is no indicator lighted on the dash, no one would know that the code has been activated.
  #19
Old 02-02-2011, 12:29 AM
Stripes's Avatar
THANK YOU!!!!!!!!!!!!
I've had the light on for a few weeks after installing a viper alarm system and the only info I had found was that you had to take it to the dealership and cough up $100 to get it reset
just took care of it and the code is cleared, now I can have people in the car!!!!!!!!!!!!!
  #20
Old 05-28-2011, 04:51 PM
fwparker3's Avatar
Thanks MHUTCHENS for the pdf link. Replaced passenger side airbag and cleared the codes = no more SRS light.
Quick Reply: reset SRS light
