17" wheels
Old Feb 14, 2008 | 06:58 AM
Aftermidnight's Avatar
Default 17" wheels
My 1995 Red 854 Turbo is lusting after some Canisto's.
I found some nice Kumho AST's and I am wondering about the size.
It is true that the 225's will rub? The Kumho's are 205's any problems?
all insight welcomed. Thanks.
Old Feb 14, 2008 | 07:12 AM
JimKW's Avatar
Default RE: 17" wheels
I run 215's on my 17" wheels. The 205's are what is called for by the factory and I have heard the 225's will rub quite a bit, but there are several who run them. I have Yokohamas and I'm not real crazy about them to tell the truth.
I have 15" Kumhos on my white car and 15" Michelins on my wagon. The Michelins are the better riding and better in the snow for sure. Not sure they are worth the difference in price when buying them though. Somehow I got a really good deal on the Michelins and when I tried to get another set for the same price for the white car, they would not even come close. The Kumhos seem like a real good tire for the money though.
Old Feb 14, 2008 | 09:01 AM
jks2's Avatar
We put 16" Mimas, with 205/55/16 on my sons 850 and there is still some room, although I'm not sure exactly how much. Specs call for a 205/45/17 tire with 17" wheels. I put 225/45/17 on with a set of Canisto's on my S60. I still have alot of room, but I'm sure the suspension makes a difference. If your suspension is lowered then they would most likely rub. If not it could be close. Your not going with that much wider of a tire so I think I would tend to go safe and stick with the 205's.
Old Feb 14, 2008 | 10:44 AM
JimKW's Avatar
Quite a few more available in 215. That's why most people go with the 215.
Old Feb 15, 2008 | 12:20 AM
thanks for the clairification.
Old Feb 19, 2008 | 02:50 AM
I found some Volans.
The tires I found are the Kumho AST 205/50/17 any problems with a 50 instead of 45?
Thanks.
Old Feb 19, 2008 | 05:22 AM
jks2's Avatar
A 50 has more sidewall height so it will fill the wheel well more. This could lead to a higher chance of rubbing.
Old Feb 19, 2008 | 07:53 AM
JimKW's Avatar
Going to throw your speedometer and oddometer off too. I would not go with 205/50/17 personally.
Old Feb 19, 2008 | 10:23 AM
jks2's Avatar
Ditto what JimKW says. Better to stick with the recommended tire.
Old Feb 19, 2008 | 05:32 PM
and that would be 45/17 with 215 or 205.
Thanks.
Old Feb 20, 2008 | 05:26 AM
jks2's Avatar
215 is just 10mm wider than the 205. Specs call for 205. Wider tire (215) would run more of a chance of rubbing on full lock turns. I personally like a little wider tire. As long as you stay with a 45 sidewall then I think it is more of a personal preference at that point.
Old Feb 20, 2008 | 03:36 PM
RedTurbo850's Avatar
^Not really. Remember, the 45 isn't 45mm. It's 45% of the width of the tire.
Volvorator
Dec 12, 2017 06:00 PM
pete13
Apr 19, 2005 10:56 PM
alecw81
Feb 28, 2005 03:17 AM
johnboy1967
Dec 3, 2004 10:44 PM
freudslip
Dec 3, 2004 03:01 AM
