seatbelt stuck
seatbelt stuck
I've just bee going over some of the posts and think this is a great site. I have a '95 850 turbo wagon (which is my third Volvo over the years). The problem: the rear seatbelt on the driver's side is stuck. I mean really stuck. Is there a "secret" little switch that will loosen it?
RE: seatbelt stuck
No there is not most of the time what you have to do is loosen the bottom part of the seat belt where it is bolted to the floor.Then let a little in and it should pull back out.
Most of the time they will lock when you are folding the seats down.
I reccomend pulling some out before folding.
RE: seatbelt stuck
Hi Tech,
Finally got a closer look at the seatbelt. By the way did I mention my 850 is a wagon? The belt is definitely stuck tight. There are some sort of plastic pop rivets around the casing and tried to "pop" them off without any success. Maybe they need to be drilled out to get at the mechanism. Any suggestions?
