Megasquirting a 850
Old 01-08-2009, 08:13 AM
Patriq Backlund's Avatar
Default Megasquirting a 850
I'm planning to MegaSquirt my 2.0 10V 850.
I understand there is an immobilizer on it. So if brake the seal and remove the OEM ECU, could I hook in between the ECU and the harness and have the ECU connected to enable the immobilizer - but tap in to all engine controls and have the MegaSquirt unit run the engine ?
Or - is all immoblizing within the ECU, so that when the MegaSquirt runs the engine - there won't be anything hindering the engine from running properly ? There's no remotely mounted unit that disables the fuel pump or anything ?
What would happen if I put the stock ECU back after taking it out ?
Old 01-08-2009, 08:46 AM
TIPSP's Avatar
Got Boost?
Default RE: Megasquirting a 850
There might be a couple people here who are running MS. I am not familar with MS so I cant help you. I do know that the guys over at turbobricks.com could tell you what you want.
