Synthetic Oil Vs Normal Oil?
Supp people, i m new to this forum lolol. Which would u recoment for a 1995 850 GLT with an NA enigne, synthetic or normal. I drive the car really hard i probebly red lineit alot, and race it alot also mostly every day. some people told me if i switch to synthetic oil, i cant go back to normal oil. WHich one would u recomend for performance that wont harm the car?
on
1 Post
RE: Synthetic Oil Vs Normal Oil?
You shouldn't be keeping your car at redline no matter which oil you use. It also doesn't help you go faster I forget how the power curve is for these engines but the power band is not at redline.
If you switch to syn be prepared for some leaks as engine gunk gets cleaned out.
Why are you racing an NA engine?
Hello Mr. Viraaj,
Greetings from Chicagoland.
Mr. info2x is absolutely right, you shouldn't be red-lining so often. For NA engines, you wouldn't need full-synthetic oils, they are more suitable for high-performance engines (turbocharged, etc...). The max horse power and max torque reach at slightly different RPMs, but for passenger cars they are usually around 4,000-5,500 RPM range. There is nothing good about red-lining an engine (accelerated wear, fuel waste, etc...).
If you plan to continue making the engine work hard, synthetic blend may help a bit. But as Mr. info2x has noted, expect a small leak as synthetic oils have tendency to leak from tiny passages.
For North American climate, I would recommend name-brand 10W-30 oil, though many shops use 5W-30. There might not be much difference, but oil warms up after a few minutes of idling after starting, and the viscosity comes down accordingly. Anyway, use whatever the oil you feel most comfortable with, just make sure to choose name brand (Mobil, Castrol, Valvoline, Pennzoil, etc...).
Cheers,
JPN
Cheers,
JPN
Im going to place some pics on my myspace in a few days, ill send u guys the URL. Duno, im still havin second thought cause alot of people told me that synthetic oil is a bit thinner so it will find its way through gaps and will start to leak. wont this ruin the performace of the car because the oil preassure will drop??
The following URL's may clear your concerns:
http://www.valvoline.com/pages/produ...asp?product=19
http://www.castrol.com/castrol/produ...tentId=6030793
http://www.mobiloil.com/USA-English/...ynthetics.aspx
According to the above MFG's, synthetic oil is fully compatible with conventional oil. When you change oil, fully drain & use a new filter, this would let you use any oil (well, probably not cooking oil).
Synthetic oil seems to be most suitable for high-pressure + high-temp applications. I work on turbine-powered (jet engine) airplanes and the oil used for those engines are full synthetic. "thinner" may not be the word for synthetic, "slippery" is more accurate. But synthetic oil seems to stay on metal surface quite well, as I have difficulty wiping off my can opener after opening a can of jet oil. Oil pressure shouldn't drop with synthetic, but if you are worried try more viscous grade oil (10W-40?).
850's have leak-favorite spots (oil cooler line, filler cap, etc...). If you find leak, you might want to fix the leak or switch back to conventional oil.
I would use synthetic oil too, if your car has added turbo and puts out 300hp. But if you plan to keep your car longer, I wouldn't make it work so hard, even with synthetic oil.
Good luck,
JPN
Good luck,
JPN
ORIGINAL: Viraaj
