Radiator smoking/steaming
Old 11-13-2007, 08:21 AM
Hondu5's Avatar
Default Radiator smoking/steaming
I just purchased a 96 turbo. I got the battery issue taken care of now I have a new one. Once the car gets warm it basically immediately jumps to too hot. Shortly after it starts smoking/steaming from the radiator area. I was testing it in my driveway but it was dark out and I didn't have a lot of lights so it was hard to tell exactly where it was coming from, plus a lot was going into my face so it was hard to see. The radiator was still cool to the touch even though it was steaming.
I took it for a ride today. The temp goes up to red then down to the middle area back and forth. The smoking is somewhat constant. Not sure if this makes a difference but it always comes out of the right (passenger) side. I just bought this car so I'd rather not have to buy a new radiator. The over flow tank is full.
Old 11-13-2007, 01:35 PM
jks2's Avatar
Default RE: Radiator smoking/steaming
Sounds like part of the radiator could be clogged. You might try flushing and refilling with new anti freeze.
Old 11-13-2007, 06:17 PM
Soounds like you might have a bad thermostat and maybe even a bad fan or relay.
Old 11-14-2007, 08:15 AM
Systek's Avatar
replace the thermostat first...
Old 11-14-2007, 05:38 PM
JimKW's Avatar
I would not drive it until the thermosat is changed. Sounds like it's not opening and closing and getting stuck closed. Stuck open means no heat. Stuck closed means no flow of coolant.
mikeawd850
11-30-2012 02:26 AM
ptaylor01
05-19-2011 10:45 AM
monte_c_lee
03-20-2010 08:39 PM
jack2403
08-08-2006 01:25 AM
danny
09-19-2005 01:53 AM
Quick Reply: Radiator smoking/steaming
