Volvo 850 Cranks, Sparks, Fuel Pump yet does not start 850 1994
Old 01-18-2009, 07:56 PM
cmercon's Avatar
Default Volvo 850 Cranks, Sparks, Fuel Pump yet does not start 850 1994
3 days ago it was quite cold and I could not get my 850 to start. It cranked and because of the -20 I figured it wouldent go. The next day I tried it, nothing just a click. I put it in the garage (with some manual labor)and there it sat untill I was able to get at it today. I come to find out that the starter was to blame for the just click. So I replaced that and now it will crank over. It sounds like a totally different car, but it will not start.
Fuel pump controler was switched with a one from my parts 850 and the car has spark. The fuel pump acuates and does its cycle.
Any thoughts as to the cause? The car ran great before this.
I initally thought It could have something to do with the vaccum lines above the radiator which I disconnected when replacing the starter. I may have them set up wrong? I took the computer module boxes out and put them inside to warm up incase that was the cause about 2 days ago. did it reset or something?
Thank you in advance.
Old 01-18-2009, 08:23 PM
Default RE: Volvo 850 Cranks, Sparks, Fuel Pump yet does not start 850 1994
Any codes in the system?
Learn how to pull them here.
http://www.troublecodes.net/Volvo/
If you have fuel,spark,Injector pulse then it should start.
Does it sound like it has low compression.
Old 01-18-2009, 08:38 PM
cmercon's Avatar
Yes could very well be low compression. Sounds from reading like it has LMS (lawn mower syndrom?) and the code box is missing from this perticular 850 so its a hunt.
Thank you.
Old 01-18-2009, 08:43 PM
If it sounds like low compression make sure the battery is fully charged and if you can leave the charger on.
Then push and hold the gas pedal to the floor before turning the key on. Then keeping gas pedal to the floor crank that motor over for a while. If the lifters are collapsed it will take like 2 to 3 minutes or more of cranking to pump them back up. Keep it cranking. If it sounds like it is going to crank just keep going till it starts.
Old 01-18-2009, 08:47 PM
cmercon's Avatar
I will try it tomorow. While I'm at it I was wondering. Is it possible that during the attempted start at -20it jumped time?
Thank you, anything else?
Old 01-18-2009, 08:57 PM
I doubt it jumped time.
Old 01-18-2009, 09:15 PM
cmercon's Avatar
All right, expert doubts eliminate that option.
Thanks,
Anything else?
Old 01-18-2009, 09:18 PM
Not that I can think of Maybe Mass Flow sensor. If it doesn't start trying the other thing unplug the Mass Flow sensor and try to start it.
Old 01-18-2009, 09:22 PM
cmercon's Avatar
Ah, maybe. What might have caused that?
I'll put it on the list
thanks,
anything else?
Old 01-18-2009, 09:24 PM
Nothing else right now. Try to find the Diag plug and pull the codes. If it isn't on the ECU box check below it and see if it fell down.
Old 01-18-2009, 09:35 PM
cmercon's Avatar
OK, well ill try all that and let you know
Old 01-19-2009, 06:39 PM
cmercon's Avatar
Looks like it was the ol' lawnmower syndrome.
Cranked it for around three and a half minutes and it popped off and went.
Why is it called lawnmower syndrome?
Thank you!
Old 01-19-2009, 08:24 PM
Me im not sure why they call it that. I just call it collapsed lifters.
Old 01-19-2009, 09:00 PM
cmercon's Avatar
Ah well upward and onward. Now I gotta fix the heater blower.
AlexMacDonald
02-04-2023 10:31 PM
nightmarevolvo
02-04-2023 06:20 PM
boxpin
09-01-2020 12:48 AM
mracr
02-14-2007 12:53 PM
Quick Reply: Volvo 850 Cranks, Sparks, Fuel Pump yet does not start 850 1994
