Volvo 850 Engine Interchange: Auto motor in a 5-Speed car?
Old 02-25-2008, 09:00 AM
markgrne's Avatar
Default Volvo 850 Engine Interchange: Auto motor in a 5-Speed car?
850 Engine Swap: Can I easily convert an auto. trans 850 engine for use in a 5 speed 850 GLT car? Both are 1993 2.3 20-V models, non-turbo. Do I have to do anything other than change the flywheel? Are motor mounts or wiring different? Has anybody done this? Also, does it matter if one car is 4-lug and other has 5-lug wheels? Thanks!
Mark
Old 02-25-2008, 05:35 PM
Default RE: Volvo 850 Engine Interchange: Auto motor in a 5-Speed car?
Everything should be the same.
Just change over the flywheel and you should be good to go.
Old 02-26-2008, 08:31 AM
Psaboic's Avatar
Tech beat me to it <grin> Yep, it should swap over with mimimal trouble
Old 03-01-2008, 10:12 PM
I don't know about volvo but this isn't universal to all cars / Sometimes
with fuel injected and even carberated you will need to keep the manual version intake and fuel related components. They might look the same sometimes but the sensors are different and could give you sluggish response
but you should have zero problems as long as the original sensors are used
This applys to most cars as well.
Old 03-01-2008, 10:22 PM
Cars this won't work on are example ford taraus SHO with 3.0 manual but 3.2 liter automatic engine so big up yourself for doing your research and don't believe everything you hear espeacially if its coming from a parts person (Autozone)
bond007
01-27-2011 03:49 PM
zak66
11-19-2010 08:50 PM
jimnash
02-12-2006 12:28 PM
jimnash
Engine & Internal
02-03-2006 05:52 PM
parrym
11-07-2004 11:30 AM
Quick Reply: Volvo 850 Engine Interchange: Auto motor in a 5-Speed car?
