Volvo Jack Points
Volvo Jack Points
Where do I jack my car up? Do I put the jack on that triangular looking thing? It has a rounded "top".
Also, where do I put the jack stands? In the "grooves" located all along the bottom of the car? (The grooves are kind of built into the body panel...)
I want to make sure. Wouldn't want to die while working on the car. LOL.
Edit: If anyone could get me pics, I would extrememly grateful.
RE: Volvo Jack Points
I found this.
http://www.volvospeed.com/Repair/jackingpoints.php
However, I don't see anything of that color under the car. There is only the triangular looking thing which connects about from wheel to wheel. The a lot of the car is black w/ all kinds of splash guards...
I just found this pic.
Is this the correct placement?
http://volvospeed.com/vs_forum/index...hl=jack+points
I used the triangular thing (you can see it in the first pic)
Hi Jimmy,
Also, J. Telectro once had the same question and people replied with a number of useful info. See if you can find the post, it should be within the first 5 pages or so I believe. Actually, I found it, what a helpful guy I am, this is what I call "The American Way":
https://volvoforums.com/m_47974/tm.htm
Make sure to use high-quality jackstands that hold more than 3 tons. I bought Craftsman's 3.5 ton units for about $20. I wanted to pay more to get made in USA, but Craftsman didn't have any. Here's the one I bought:
http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
After you place the car on the jack stands, make sure to "shake" the car to see if there is any play/looseness. It should feel solid if seated properly. Also, do this on a level surface. Put the shifter into "P" or "1", apply P-brakes fully and place chocks if available.
When working under the car, I would wear eye-protection. You'll get dripping oil, coolant, loose metal chips, etc...
I just found your 2nd reply, are you referring to the rear? If so, go over J. Telectro's post, I think there was a reply that noted a jacking point for the rear. I wouldn't place the jack stands under the "triangular" thing, if you're referring to the transverse arm. You could bend the arm and screw up the alignment.
ADDITION:
I just found your 3rd reply.
I wouldn't place jack stands where the pic shows, unless Tech or someone thinks it's safe. If lifting the front, use sub-frame. Also, when you use floor jack to lift the car, use a piece of wood or something to avoid damaging the sub-frame.
Be safe.
JPN
ADDITION:
Be safe.
JPN
on
1 Post
ORIGINAL: JPN
Be safe.
JPN
Be safe.
JPN
This is the setup that I used when I did my sway bars a few weeks ago. I had jacks at the point in question (with wood between the jack and my car) as well as the mid jacking points that the factory jack attaches. The other jack (center) was to help lower the sub frame.
ORIGINAL: info2x
As long as you are close to that triangle bracket that goes to the sub frame you should be fine. That is where the dealer puts their lift I believe.
ORIGINAL: JPN
Be safe.
JPN
Be safe.
JPN
LoL, JPN, I found all those pics already. Hahah. I tried to use that, but I can't find the miscolored thing that they have in the pics.. I think my jackstands hold 2 tons, as well as the jack. I only need the front as I'm changing the t-stat out.
As to Tech, I will put the jackstands by the 2 little screws as per your advice.
I'm still gonna do a little bit more reading though, I don't want to die. LOL.
Hi Jimmy,
I tried all 3 links I provided and they all worked for me.
I am not sure if 2-ton stands are sufficient, as 850 is a heavy one. Ask Tech to see if 2-ton is strong enough. I usually don't trust nominal capacity and go with a bit of extra, so I went with 3.5-ton.
Unless you plan to drain the engine block, you do not have to raise the front. But if you do plan to drain the block, I suggest that you put some thread sealant on the threads of the petcock when putting it back on the block. As for the petcock on the radiator, finger-tight plus 1/8 turn will suffice. It's plastic, so if you tighten it too much, it'll break off. Attaching rubber hoses on the 2 petcocks makes the job a lot neater.
Anyway, I've always used the sub-frame for the front-end jobs to place the stands.
JPN
JPN
on
1 Post
ORIGINAL: RedTurbo850
^LOL. Extra Safety...Did I count correct? 5 jacks/jackstands? LOL.
I used the triangular looking thing w/ near the widest point w/ the 2 bolts. Thanks for the help. Got that t-stat changed, now the car seems to run better (unless its placebo effect...)
It looks like over the course of years & site upgrades, none of the links or images on this thread work anymore. I'm specifically looking for a good spot to raise the rear of our 850 GLT up. is there actually a good location? Or am I left with raising one side, then the other? (obviously i have jack stands to use too
A helpful diagram of the best jacking points (other than those two on the middle of each side) would really help!
Thanks!
-Chris
Thanks!
-Chris
