VOLVO-VOLVO TECH - WHERE ARE YOU?.
I have '95 850 non-turbo -yesterday got CE light -pulled 231 code from A1 and could not clear it first. Then pulled a couple of codes for rear ABS sensors ( I think left there since State inspection on a dyno, when only fron wheels are moving), cleared those, and was able to clear 231 as well. I also got 122 code from B2 socket, but was unable to clear that one. Started the car and got ABS and TRACKS lights on the instrument cluster -drove off, and both lights went off in a minute or two.
Today, looked under the hood and found broken air hose (from air box to intake). which I assume set 231 code from A1. Also found same 122 code from B2 socket. tried to clear w/ no result, and decided to disconnect the battery for 15-20 min. Replaced air hose as well as a couple of rubber connectors bet. vacuum tower and flame trap. Checked for codes in A- box - none. Checked B2 and got 122 again. Could not clear it, and after trying clearing 2-3 times found ABS and TRACS light on. Re-started the car -no more ABS/TRACS on.
The car runs fine, I just want to know what is 122 from B2? I found some info that it is a cruise control code?..
Thanks to everyone for your help.
Yuri
1995 GLT w/ CD changer, fogs, no trip computer.
PS
I use the car every day for my job, and cannot relax when driving if I know that something is or might be wrong w/ the car...
Yuri
PS
RE: VOLVO-VOLVO TECH - WHERE ARE YOU?.
Founf this:
"B2(cruise control)122=speed has not exceded 35km/h or no vehicle speed (which is normal)If you do the test after driving and not shutting the car off then you will get a 111"
- I will try it tonight.
Still not sure why trying to clear it triggered ABS/TRACS.
