What cylinder heads will interchange?
I am repairing a customer's '94 850 Turbo, which I have determined to have both a burned exhaust valve AND a cracked head. This car has the 2.3L Turbo engine. What cylinder heads can I use here? Specifically, can I use the head from a '97 2.4L low pressure turbo, or does it need to come from a 2.3L? I could wait until tomorrow and ask my usual salvage yard to do an interchange, but I'd kind of like to find out tonight. Thanks!
Okay... I checked on this one, and it turns out that all 850 turbos from 1994 to 1997 have the same head (thank god!) Why do I say this? well... time for a little confession. I did a PCV system on a customer's 94 850 the other day, and the next day, I get a call that the car has no power and is shaking. I go to check it out, and no compression on cylinder 4. do a leak- down test... it's an intake valve. My dumb **** probably dropped a bolt or something while working on it and didn't see it. So... I have to change out the head. And I know where I can get a very good '97 850 2.4 Turbo head fairly inexpensively so that I don't completely lose out. Now I'm just out the cost of a head set, the head, and labor... ah, well. I guess I'll check the intake ports first next time before reinstalling the manifold
Thanks... but I found out that the head is the same on the known- good '97 850 Turbo engine I have access to. If it turns out otherwise, I may be talking to you
Along the same lines as the original question, I'm looking at a 97 v70 turbo wagon. Low kms compared to my 95 850 N/A. The v70 has a head problem whether its a gasket or the head. I'm told it had overheating problems even though the water pump is apparently fine.
Would the head from my 95 850 work on the v70 considering one is turbo and one is N/A?
cheers
cheers
MT and tryingbe,
I have a 1996 850 NA with MT. The head is ok, but prior owner was really negligent.
In case I need a new head, can this one (NA) be replaced with a turbo head, since the turbo models are much more available?
Thanks!
