Wheel Lug Compatibility - Volvo Forums - Volvo Enthusiasts Forum
LinkBack Thread Tools Search this Thread
Old 10-25-2009, 12:43 PM
Default Wheel Lug Compatibility
Have a 94 850 and 98 V70
Can anyone tell me what other wheel lug patterns are compatible? Looging on Craigslist for winter tires/wheels and there are alot out there for S60/S80 etc.
Thanks,
Chris
Old 10-25-2009, 01:09 PM
gilber33's Avatar
They're all 5x108, just depends on the offset and I dunno if the bore size is different between the cars or not.
Old 10-26-2009, 09:24 AM
I seem to remember that the 94's had a 4 lug hub. If that is the case then you wouldn't be able to switch wheels. If they are both 5 x 108 then fitting would not be a problem. Just try to keep the offset similar.
Old 10-26-2009, 09:29 AM
I would suggest going to a junk yard that has volvo's and get a set of wheels there. Then get some winter tires for them. They have some good ALL SEASON tire out now that may work for you as well.
I can remember a while back that iPd or some company sold some studded snow belts that were easy to put on and take off for those bad snow days.
Old 10-26-2009, 12:44 PM
gilber33's Avatar
Quote:
93's were 4 lug, then 94's and up were the 5x108
Old 10-26-2009, 02:13 PM
Former Sponsor
Pretty much every Volvo ever made was a 5x108 with the exception of the 93 Volvo 850. Also, all the FWD cars and the Volvo 960 have the same offset.
Old 10-26-2009, 04:00 PM
93 or 94, I couldn't remember. Thanks for the correction.
Old 10-26-2009, 08:50 PM
Thanks FCP, and everyone else too. Got an drier/accumulator from FCP, worked great...thanks!
Chris
Old 10-26-2009, 10:19 PM
850tony's Avatar
the s40 (2000-2004) has a four lug setup. i think the rest are 5 lug
Old 10-26-2009, 10:32 PM
gilber33's Avatar
All the way until 2004 the S40 was four lug??? Weird.
Old 10-26-2009, 10:53 PM
850tony's Avatar
i *think* so. the early builds were 4 lug as far as i have seen. 05+ were the late builds.
Old 10-27-2009, 09:34 PM
Quote:
The S40 until 2004 was an unusual car. It was actually a joint project between Volvo and Mitsubishi, built in the Netherlands. Mitsubishi sold it as the Mitsubishi Carisma in Europe. Thankfully, there wasn't a whole lot of parts on that car that was actually Mitsubishi- sourced, but I'm guessing that the hubs might be.
See: http://en.wikipedia.org/wiki/Mitsubishi_Carisma for more info.
Thread Thread Starter Forum Replies Last Post
4 lug to 5 lug conversion?? 5cylinderkiller Volvo 850 2 01-27-2014 07:16 PM
Wheel spacers/ lug nuts ? steph Volvo XC90 4 09-23-2011 07:48 AM
OEM Volvo Wheel Lock Lug Trouble MikeySq Volvo V70 11 06-21-2009 10:32 AM
Wheel Lug Bolts raybun Volvo 850 3 01-17-2009 09:48 AM
Mag wheel lug nuts torque specs ? moosepucky Volvo 240, 740 & 940 1 08-03-2008 05:29 PM
Tags
850, 93, 960, bore, compatibility, compatible, hub, lug, offset, patterns, s4o, s60, volvo, wheel, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
