oil leaking behind #5 exhaust port
Old 04-24-2010, 06:18 PM
91shelby's Avatar
Default oil leaking behind #5 exhaust port
i noticed a little bit of oil leaking down the block behind the #5 exhaust port what around there could cause this?
Old 04-24-2010, 09:08 PM
bostongrun's Avatar
I will bet that it's camshaft position sensor. It's too high for the turbo oilreturn. Volvo don't have a convential valve so it's not likely a valve cover leak. The cam sensor oil seal is not hard of a job. I think you have to make a specail tool to hold the cams. It's not to hard (see Haynes manual)
Old 04-24-2010, 10:06 PM
gilber33's Avatar
Nah, you don't necessarily need a cam lock tool. I swapped cams once with a tool and the second time without, just watch what you're doing.
hikerguy
08-11-2013 05:35 PM
MainerInMitten
11-08-2012 02:11 AM
sgreenfield
05-26-2012 10:01 AM
dlennox2001
Penta
02-08-2006 06:25 PM
Quick Reply: oil leaking behind #5 exhaust port
