Where does your temp gauge sit when your car is warmed up?
Old 02-02-2015, 11:35 PM
bctom's Avatar
Default Where does your temp gauge sit when your car is warmed up?
The temp gauge in my non turbo 850 seems to barely move when the car should be up to operating temperature. The heater puts heat though.
I suspect the thermostat is stuck open but I`m wondering if anyone could let me know what the temp gauge in your car shows when your car is warmed up.
Thanks
Old 02-03-2015, 07:05 AM
dorvin's Avatar
Typically, when my car is warmed up, the temp gauge sits right at about the 3pm mark, or about in the middle of the gauge.
Old 02-03-2015, 11:13 PM
TonyS's Avatar
Same. 3 o'clock.
Old 02-05-2015, 01:18 PM
firebirdparts's Avatar
Same here; I see a horizontal gauge needle. All the 850's I've had were the same.
Old 02-05-2015, 09:11 PM
bctom's Avatar
Thanks for the reply's.
Idling with the A/C on the most I can get is 0430.
Must be time for a new thermostat and coolant.
Old 02-06-2015, 06:31 PM
Be a good idea to change them out and then see where you are at.
Old 02-14-2015, 10:31 PM
Do it ASAP. Running a car with a bad thermostat will cause it to run rich. That can lead to a burnt valve.
Old 02-21-2015, 11:05 AM
cem308's Avatar
Mine sits just above 3 oclock. My heat gun says 192 at the thermo housing.
Old 03-07-2015, 09:08 PM
Erik Strieter's Avatar
My 95 sits right in the middle.
bigezman
10-25-2011 07:03 PM
blackbrick
05-07-2011 01:46 PM
ruggles
01-16-2011 05:30 PM
vcolper
11-01-2006 10:20 PM
Quick Reply: Where does your temp gauge sit when your car is warmed up?
