Whining noise - Volvo Forums - Volvo Enthusiasts Forum
Thread Tools Search this Thread
Old 01-23-2008, 07:12 PM
Default Whining noise
After cold start this morning I have noticed a wining noise in timingbelt area, it is hard to say though where it isexactly coming from but it’s definitely on a left side of the engine. Once car wormed up a little bit it was gone, I let it cool off and the same noise came up again when i started it. I have changed timing belt this summer but I haven’t touched anything else there. Any idea what it is?
Old 01-23-2008, 07:23 PM
Default RE: Wining noise
Most likely a bad tensioner or idler pulley. (timing belt)
Old 01-23-2008, 07:41 PM
yeah i would think that is tensioner because i was messing with it couple of times by compressing it with clamp .
how soon it should bereplaced or can i still run on it for a little bit?
Old 01-24-2008, 06:43 PM
It has got to be one of the pulley's not the hydrolic part itself.
I would replace as soon as you can if it comes apart you will be looking at about 3k for the repair.
Old 01-25-2008, 09:38 AM
Psaboic's Avatar
When it is cold out, our 850 has a groan/moan sound that is RPM dependent from the timing belt area. It lasts for about 30 sec or so then goes away. I ahve used belt dressing and it seems to help. Just my .02
Old 01-26-2008, 12:37 AM
how hard is pulley replacement procedure?
is there anyspecial tools needed, or can i justwork it with aregular tools?
Thank you!
Old 01-26-2008, 09:58 AM
It is like replacing the timing belt.
One is held on with 2 12MM bolts the other is held in with a T-45 I believe or a T-40.
I bought one and cut it down some to fit properly.
Thread Thread Starter Forum Replies Last Post
high-pitched whining noise cetaphil Volvo S60 & V60 8 03-23-2009 09:27 PM
Whining noise in dash gdstuart Volvo V70 4 07-22-2007 04:40 AM
Whining Noise from Rear of car! 2006S60R Volvo S60 & V60 2 07-07-2007 11:11 AM
Front end whining noise johnhon Volvo XC70 9 10-21-2006 08:27 PM
V70 Whining/droning noise conoros Volvo V70 2 09-27-2006 07:50 PM
Tags
850, belt, c70t5, cold, corvair, noise, pulley, rear, replacement, sound, start, timing, volvo, whine, whining, whirring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
