C30 2.0 (2009) starts, runs for 2 seconds then stops
Old 03-02-2015, 02:16 AM
southislander's Avatar
Default C30 2.0 (2009) starts, runs for 2 seconds then stops
Hi,
My Volvo C30 2.0, auto, 2009, 80k kms.
I never had problems up to now. Today, I had a drive around 30 kms, parked it for 6 hours, then when I try to start again, engine started without any problem, it stays in the idle around 1-2 seconds, then stoped. It feels that there no fuel been pumped. During this 2 seconds interval, the gas pedal is useless - even I press on it, the rev is not going up. No warning lights on the dashboard. I tried 5 times, all the same. I have locked the car and unlocked a couple of times, it did not help as well.
Any ideas what to check?
Thanks.
Old 03-03-2015, 03:38 PM
We found that the problem is the fuel pump. It seems the 2.0 litres (Mazda engine that comes from Ford partnership) do not have a fuel pressure sensor and I have told that all unit needs to replaced. Still investigating.
Old 03-04-2015, 03:38 PM
it was certainly the fuel pump, not the whole unit, juts the pump inside the unit. it was replaced with a ford spare part as these engines were provided by Ford. Pump cost around 150 USD (i am quite sure prices a bit higher here at New Zealand) and 4 hours of labour.
Dan Daws
07-19-2015 12:05 AM
johnb317
05-13-2013 12:43 PM
xaiox20
04-30-2012 04:15 AM
victory
02-11-2009 07:39 PM
dbehr
09-30-2004 09:46 AM
Quick Reply: C30 2.0 (2009) starts, runs for 2 seconds then stops
