c70 ets light - Volvo Forums - Volvo Enthusiasts Forum
Thread Tools Search this Thread
Old 11-20-2010, 10:32 AM
Default c70 ets light
I recently purchased a 2000 c70. The ets light came on, went to volvo had the new software downloaded and the light went off for about 100 miles - now it is back on. I have been driving about 8 months with this light on and the car runs fine. I don't care much for warning lights - they don't bother me - I paid 4000 for the car and volvo wants $1300 for a new ets module. I've read where sometime they only last for a year. Anybody drive theres into the ground with this light on?
Old 12-02-2010, 02:39 PM
If it goes you will be stranded. I don't think you can pass smog with this light on (at least here in California). There is a company that can rebuild your existing ETS called Xemodex. I believe they replace the mechanical parts that wear out with electronic equivalents. I haven't tried them but when my ETS comes on that is the path I'm going down.
Old 12-06-2010, 07:21 AM
Default throttle
Quote:
they will last longer than a year but have some unfixable issues .Moisture is one and the inability to read the pots in the module after a while .Usually throttle response goes all together .There is extended warranty up to 100k .Later brit ..
Old 12-27-2010, 06:58 PM
The ETS light on my '98 C70 Coupe (2.5t LPT) comes to magazines. They also hunt, while idling. I checked out of a Volvo engineer who thought the problem could throttle the Volvo Control Module (TCM) and the unit should be replaced rather than the pedal or ędrive-by-wire" system.
Thread Thread Starter Forum Replies Last Post
First ETS light, then fine, now Engine light and shaking engine/no power Pej Volvo S70 0 12-27-2012 01:01 PM
2000 C70 conv~ 2500rpm engine cut out/ ETS light greasedlightning Volvo C70 2 07-14-2010 11:45 PM
C70 Coupe ETS problem sterling157 Volvo C70 9 06-06-2009 10:52 AM
help,,c70 99 ets light on ,,,anyone distraught Volvo C70 3 02-26-2009 05:51 PM
2000 Volvo C70 ETS Light - please help djxtc21 Volvo C70 1 08-02-2006 10:39 PM
Tags
2000, 70, c70, car, charger, drive, drives, ets, fine, idles, light, smog, test, volvo, warning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
