Fuel door and drivers lock won't work- related?
I can't operate the remote fuel door using the lever on the driver's door on my 99 C70 ... I have to use the cord in the trunk. There is no sound coming from the gas door area when the lever is pressed.
Also, the button on the driver's door to lock both doors does not work (the one on the passenger door does, though).
I have read that the gas door is somehow connected to the locking system, so I was wondering if these are possibly related.
I suppose I could replace the lock switch first and see if they both start working.
RE: Fuel door and drivers lock won't work- related?
There is a weird thing that happens sometimes, if you look at the passenger door switch, there is a toggle switch for locking/unlocking the doors. If that switch sticks in the lock or unlock position, it will prevent the entire lock system from working, which include the gas door and trunk.
B
B
I got it!
The connector had come off of the back side of the power door button ... the toggle one that is a master door lock.
This fixed the door locking problem, of course, as well as the fuel door issue (weird).
(The trunk was still working all the time, though.)
