How do I remove my back seat on a c70???
I'll give you my knowledge on the coupe; facing the rear seat, place a long screwdriver under the seat at about 12 inches from your left hand side and help it with your hand lifting it straight up; do the same on your right side. I may be wrong, therefore be gentle ... not to much force. If that comes out up, you'll see a 10mm screw in the lower level bottom at either side of the back seat rest; take those out and lift gently the back rest, reach behind for the head rest release push plastics .. you have to feel them .. push in while you push up the head rest. The arm rest can be taken out after all this. Let me know if that works and I tell more.
Woober
09-28-2014 10:18 PM
AnEskimo
05-16-2010 06:19 PM
