Sensor output parameter list
Sensors
Mine are packed away, just moved to winter home. They can be ordered on line. What are your codes or problems? You can inspect the wheel sensors by just removing each wheel. I have a new set for mine but haven't installed, just doing the over 10yr. maintenance. OBD2 sensors are easy to test/replace, I have the special slotted socket for them, swapping them can help troubleshooting or replace with used or new. I put new ones in mine after got a code a few yrs. ago. Cleaning plugs every 1 or 2 yrs. is easy & gives you an idea of engine condition. Some troubleshooting can be done by just swapping similar parts from 1 cylinder to another. I cleared the darn "service" light on problem by removing both modules 4 24 hrs. Helps to have several vehicles. Let us know how you are getting along. A lot of help here. Search on u-tube for videos on a lot of maintenance things and removing/replacing items.
Thank you for your input. I can start the car but it won't run except to idle. Trying to accelerate just shuts the engine down.
I got a code reader and after starting it here is what I got:
Absolute TPS - varied from 5.9 - 10.6
Engine speed - varied from 800 - 900
MAF - .73 / .76 / .86
Engine advance - 9.5 - 11.0
IAT - 55 degrees
SFTRM1 - 8.6
LTFTRM 1 - 8.6
O2S12 (V) - .435
If you can tell anything from this I would really appreciate it!
IAT - 55 degrees
SFTRM1 - 8.6
LTFTRM 1 - 8.6
O2S12 (V) - .435
mespinosa
12-01-2013 05:44 PM
