Springs on volvoc70
Springs on volvoc70
I have a Volvo C70 2.4 t get 2003 ,has just failed mot for broken back Spring,so had 2 new springs on back , now the back sticks up, this car when bought new had lowered suspension fitted,at Volvo factory,but now they don't do the kit,the Volvo local garage supplied me with 2 springs which they said should be ok,but still the back sticks up.can anyone tell what the height should be from floor to wheel arch on this car with the lowered suspension kit fitted at factory?
Can't seem to get this from Volvo . Any help would be welcome thanks caravan 1
if you present your VIN to a dealer parts dept, they can tell you the factory spring part your car was shipped with. If after delivery somebody installed new springs front and rear, then all bets are off. You may want to just consider doing all four corners with OEM or after market... but all the same.
Another solution could be a professional lowering kit with the wheel angle adjusters, I have these installed on all four springs of another car (Dodge) and they work great. These are not hard to install, or you could have them installed at your local shop. Just make sure you don't get the cheap ones that just compress the springs.
