Window regulator
Old 04-15-2016, 06:37 PM
Michael2's Avatar
Default Window regulator
I have a 2001 c70 convertible window regulator for the drivers side, motor is good but it needs the cable replaced and it doesn't have the window. Just trying to get it out of the way, if interested, make an offer.
Thanks .
Old 04-22-2016, 10:34 AM
FailedCabrio's Avatar
Thanks .
My window fell "off the rails" a few months back. After I seemingly put it back in place, it still wouldn't roll up or down. I took it to Tire Kingdom and they said I needed the wires cut, so they cut the wires.
I'm not sure how to diagnose whether or not the motors are good, but my glass is intact. However, those wires are cut.
Anyways, could you help me diagnose my problem? I'd rather not replace the entire assembly. I'd prefer to purchase only the parts I need and repair it myself.
That being said, I will gladly purchase your regulator if entirely necessary.
Old 04-25-2016, 10:33 PM
Michael2's Avatar
Failed cabrio
If you have cut the cables on the window you may have done to much, you can probably find a new cable system online but the cables have to be timed so that it will lift the window to the correct height there are some videos on YouTube about this, just make sure your motor is good before you buy the cable system. Hope this helps you.
Michael2
Old 05-01-2016, 01:14 AM
MSGTUSMC's Avatar
Replace the motor or the complete assembly or you will have problems forever!
reecesp1eces
02-02-2014 08:44 PM
sadlers
04-01-2007 10:34 PM
02VolvoS40
12-29-2006 10:10 PM
aeabston
10-29-2006 11:10 PM
xoneinax
09-14-2006 10:28 PM
Quick Reply: Window regulator
