01 S40 P0101 and P0128
Old Nov 10, 2012 | 12:56 AM
jasel610's Avatar
Default 01 S40 P0101 and P0128
I have a 2001 Volvo S40 that has been good to me. Over the past couple of months I keep getting a check engine light with a fault code of P0101 or P0128 or both (not sure if the two together should tell me something). The car has been a little laggy unless I get on it. If I take the battery wire off for about 15 mins the car runs great for about 100 miles. I tried cleaning the MAF, replacing the thermostat, new plugs, cleaning my K & N air filter, cleaning my idle air control valve, and looked and listened for any signs of air leaks. Any help would help my stress level as I am in one of those times where everything is breaking on me all at once.
Old Nov 10, 2012 | 07:57 AM
Hudini's Avatar
The P0128 for me was a bad t-stat. I'd replace it then clear the codes and see if the other code returns. If yes, then I'd clean the MAF with MAF spray cleaner (don't use a substitute), reset the code and drive it again to see if it returns again. Now if it returns again I'd bite the bullet and replace the MAF. My .02
Old Nov 10, 2012 | 06:58 PM
jasel610's Avatar
I have tried the T-stat and cleaning MAF but both fault codes returned (I also tried disconnecting the battery). What would you go with next MAF or Temp sensor at T-stat, those are my thoughts but I am hoping for advice.
Inspection is in Feb so I have time on my side.
Old Nov 10, 2012 | 07:54 PM
Hudini's Avatar
You cleared the codes with an OBD-2 reader and they immediately returned? If so then only the temp sensor is left. It's the sensor screwed into the t-stat housing. It's fairly easy to change for the DIY mechanic.
Personally I'd work on one issue at a time. Fix the issue with the coolant temp, then fix the MAF.
Old Nov 10, 2012 | 07:58 PM
jasel610's Avatar
Thats good advice, I will just stick with the temp problem and go after that sensor. Would you stick with OEM?
Old Nov 10, 2012 | 08:04 PM
Hudini's Avatar
My 2001 is too old. I just buy cheapest online if I have time to wait.
Corban L Russell
Oct 11, 2013 09:02 PM
bvallese
Oct 6, 2013 08:51 PM
crashin
Feb 26, 2011 07:10 PM
curtis.elrod
Jul 20, 2010 01:10 PM
