05 s40 2.4i
05 s40 2.4i
Hello, so this is a tuff one. I have this weird whistle type riddle noise coming from the passanger side of the engine . I tried to troubleshoot this and find the exact location. I think it's coming from the came gear area. Under the plastic shroud. The noise is only present at about 1200rpm till about 1500rpm then it disappears . But every time the car hits thoese rpm range it's is back. Super annoying and nothing makes it go away. Any suggestions?
Yes, I removed the top cover and it sounds like it's coming from the rear cam gear, I removed the intake cover also and noticed a large amount of oil on the top of the motor to the passanger side . I checked the one PVC tube for cracks but it looks to be in good shape.
Yes, here's the deal . The car only makes the noise when you hit 1200rpm. Then stops at 15-1600 rpm . The noise sounds like a Bering issue . Even if the dip stick is pulled or not the noise is still there, but when I pull the dipstick I do notice the car idles a lot better, when I push it back in it ideals rough when it comes back under pressure, this car has been plagued with oil issues sense we bought it. Sometimes I have checked the oil dipstick and the thing was bone dry. With no warning light! What's up with that! also. I did the glove test over the oil fill hole and it sucks it in . I will try to take a video of the issue today so I can show u.
