2000 S40 Low Beams - Volvo Forums - Volvo Enthusiasts Forum
Thread Tools Search this Thread
Old 01-14-2013, 04:17 PM
Default 2000 S40 Low Beams
I have a 2000 S40 - the low beams wont work, but the high beams work. I have checked the fuses (both of them) under the hood (10amp).
Any thoughts?
Old 01-16-2013, 08:10 PM
Hudini's Avatar
Bulbs burnt out? Not trying to be funny. Stranger things have happened.
Old 01-19-2013, 10:54 AM
Angry low beams
the whole story is that the passenger side went out first - put in a new H7 bulb - would not work. I ended up wiring the passenger bulb to the drivers side bulb so they would both work.
Now they are both out. fuses still good. Im going to start trying with a multimeter to hunt dont the circuit issue
JPJMustang
Old 01-19-2013, 04:10 PM
possible bulb connectors, mine burnt out at black earth wire,replaced connectors trouble gone bulb ok
Old 01-20-2013, 09:13 AM
Default Sockets
I cut the sockets off ( the plastic was starting to crack and was very weak) and wired the bulbs direct.
JPJMustang
Old 02-02-2013, 03:04 PM
JP
Do you mean that you ran a jumper wire from the working light to the non-operable one? If so....is it still working?
Old 02-05-2013, 04:08 PM
I just had this exact problem with my 2000 S40. Right headlight out a couple years ago, and the other night both dead. I had already wired the right to the left and changed bulbs. It ended up being the CEM - Central Electronic Module. It's located under the dash and fairly easy to change yourself. Not so cheap, got a used one for $250.
Old 02-05-2013, 06:24 PM
Hudini's Avatar
Good to hear a solution. Thanks for posting the info.
Old 02-05-2013, 08:52 PM
The CEM has one relay for each low beam headlight...12 VDC, 15 Amp, 240 Watts SPDT, (single pole, double throw) connected to the CEM circuit board. A few owners have reported de-soldering the bad relays, and soldering in the 5 pin replacement that costs @ $1.50 on the internet. Also, some reported success and some reported problems with used CEM's purchased on eBay. MAke sure that you look at your CEM number to procure a matching one. Apparently this is a common problem accross all recent Volvos when the bulbs/fuses are good, but there is still a headlight fail. I am working on identifying the relay.
Old 07-22-2014, 04:57 PM
Quote:
Any luck?
EDIT: Found more info: http://www.volvoforums.org.uk/showth...ight=headlight
Old 07-23-2014, 11:42 AM
The Internet company with the required relay is called Digikey.
The part number is JSM1-12V-5
Old 07-24-2014, 03:00 PM
Btw, the CEM is easy to remove, but splitting the case was maddening until I discovered a Philips screw hiding under a Volvo decal. I recommend you purchase a spring-loaded solder sucker (@ five USD) to insure a successful swap out of the relay. I am an Electrician but was still apprehensive about trying this myself, but knowing others had done it encouraged me. So glad I did.
Thread Thread Starter Forum Replies Last Post
high beams not working - low beams ok 98isb360 Volvo 240, 740 & 940 6 08-28-2015 01:46 PM
S40 weak low beams kwhitton Volvo S40 0 11-22-2010 03:10 PM
High beams work, low beams don't bkhan145 Volvo 240, 740 & 940 5 10-14-2008 11:02 PM
2001 S40 Low Beams Dead whatda? Volvo S40 2 08-09-2008 08:35 AM
2007 S40 Low Beams are worthless jasonl Volvo S40 2 08-01-2008 09:25 AM
Tags
2000, 2001, 2005, 40, beam, beams, dim, drivers, headlight, located, low, relay, s40, side, volvo, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
