2000 S40 Turbo, Gear Stuck on turbo.
Old 06-21-2013, 10:24 PM
Daniel Moreno's Avatar
Default 2000 S40 Turbo, Gear Stuck on turbo.
Hey everyone!
I have a 2000 S40 1.9 Turbo. I was driving normally with the gear on D. I was crossing a light when it turned on yellow so I floored it. The car started to accelerate like normal. Once i passed the light i hit the break and it wouldn't gear down. It kept on wanting to accelerate by it self. I've tired to change gears from D to R and to L but it wont gear down. Any suggestions?
any help would be appreciated
Old 06-21-2013, 10:45 PM
Hudini's Avatar
Check the throttle cable. Might be in need of some lube. Check the exposed cable for fraying. I've seen them look like a bird's nest which stop the cable from moving correctly.
Also check that your floor mats or anything in the floor is not interfering with the throttle pedal.
Old 06-21-2013, 11:01 PM
thanks for the quick replay and im sure its not the pedal or the throttle cable because once i let go of the pedal the car "slows" down but the motor starts to "pull" to keep on accelerating. This happened to me once before and I fixed it by putting my car on R. This made it go back to the begging gears. Do you think its the transmission?
Obelix
06-20-2022 08:40 AM
mastceh
01-12-2010 09:36 PM
bamaboifresh
12-20-2008 07:43 PM
amotin
12-12-2008 09:13 PM
atikovi
08-18-2006 12:45 AM
Quick Reply: 2000 S40 Turbo, Gear Stuck on turbo.
