2000 Volvo S&V40 Tire Bolts.
Old 08-17-2015, 05:42 PM
henrysin44's Avatar
Exclamation 2000 Volvo S&V40 Tire Bolts.
I changed my timing belt last month and had to remove the front passenger side wheel, I read to torque the tire lug nuts to 64 ftlbs when putting the tire back on. Well today I was driving and the car felt very bumpy and I was hearing a ratteling sound, pulled over to find the tire almost off and 1 of the 4 lug nuts missing and the other 3 almost off! Now 64ftlbs can't be right so what is the torque you recommend? Don't want this happening again.
Old 08-18-2015, 10:15 AM
Livens's Avatar
For the S/V 40's I think the recommendation is ~95 ft/lb. And if you have alloy wheels you should retorque them after a week or so.
Old 08-18-2015, 02:29 PM
My 2000's owners manual states 81 ft/lb = 110 nt/m. I tend to use 90-100 just the same as Livens suggests. Also its recommended to cross tighten and recheck after a short test drive...
Old 08-18-2015, 08:40 PM
migbro's Avatar
Hope you do timing belts better than you do lug nuts.
Old 08-22-2015, 08:21 PM
henrysin44's Avatar
Ha I was telling myself how can I change a timing belt but I can't tighten lug nuts, I found the rear tire also had very loose nuts too and I realized that the two tires on the passenger side facing the street I parallel park on had the bolts loosened, while the driver side wheels faceing my house where tight. Think someone was trying to do a evil prank.
Jackspratz
2001-2013 model year V70
36
06-18-2023 09:48 AM
henrysin44
07-17-2015 12:04 AM
henrysin44
07-10-2015 11:51 AM
ddrewyor
01-08-2012 03:36 PM
Garon
04-22-2009 02:57 PM
Quick Reply: 2000 Volvo S&V40 Tire Bolts.
