2001 S40: all tail lights out, but no problems with fuses
Bizarre problem happened today...all 4 tail lights went out simultaneously (a passing driver alerted me). when I got home, I checked all the fuses in engine compartment and under dash, and all were fine (tedious!). Then I checked the bulbs in the 4 rear light harnesses (2 per side), and astonishingly, all four 5W bulbs were burned out!
Is there a simple explanation for this? A short? An electrical spike?
Do I need to go to an electrical specialist instead of my local mechanic (who is terrific, but...)?
Thanks...
P.S. I inherited the car from my father. It has only 70,000km on it!
Thanks...
I replaced the 4 small tail light bulbs with the 5W type 67 bulbs recommended by Volvo ($1.99 per 2-pack)...so far so good. However, I did notice that the burnt out bulbs were not the same type recommended in the car guide! The number on the bulbs was 5007H. I recently discovered that the car had been rear-ended in a parking lot about 2 years ago (just before I inherited the car), and the lighting panel had been replaced by the auto-body repair shop. Hmmmm...
Thanks for your help
88740gle
11-13-2015 08:13 AM
volvamos
12-23-2014 08:56 PM
vladgur
07-22-2010 03:27 PM
