2001 v40 help! Where is the air inlet temp sensor??
Old 04-29-2016, 04:44 PM
Stoo's Avatar
Default 2001 v40 help! Where is the air inlet temp sensor??
Hi, am trying locate the above as I suspect it being the source of a severe hunting idle. I have cleaned the throttle body and Ian and checked off vacuum leaks and I have pulled a code for the above but can't find it! The engine is a 1.8 volvo unit with an auto box. I hope this sorts it as the car drives well and only has 56k on it and failed the MOT on emmissions! Any help appreciated!
Old 05-03-2016, 09:40 AM
Hudini's Avatar
I think.....
Old 05-03-2016, 01:01 PM
Stoo's Avatar
Thanks hudini, unfortunately that's not where it is on mine, I think that's the turbo location . I think it may be combined in the maf sensor so will give that a try....
Old 05-07-2016, 06:13 PM
Stoo's Avatar
Was indeed in the maf sensor on case this helps anyone!
Phil 850
10-14-2014 07:20 PM
dafox99
01-27-2014 08:40 AM
outdoor7or24
07-27-2010 08:42 AM
Beachbum
05-25-2010 12:30 PM
vcolper
11-01-2006 10:20 PM
Quick Reply: 2001 v40 help! Where is the air inlet temp sensor??
