2002 S40 1.9L Turbo Timing Belt???
Some mechanic in town said he wouldn't do the job because he would need to spend at least a grand just for a special tool to align the cams and losen the tensioner arm. I am hoping to do it in the drive way with basic tools. just don't want to screw it up and destroy the engine (i.e., smashing the pistons through the head on start-up).
By the way, I am also planning on doing the driver's side CV Joint on the wife's 2008 XC90 in the driveway. I got a new dis-assembled CV Joint (basically just the knuckle and bearing with a tube of grease) and want to know if I can do it with basic tools and a jack? I am only guessing that the CV Joint is going because it clicks like hell whenever I turn more than say 45 degrees in either direction. However, the boot is not ripped, and it doesn't appear to be throwing grease. I was amazed that the CV Joint would be giving me trouble so soon, but it is the onlt thing I can think of...
Any thoughts???
Any thoughts???
I have a 2001 V40 1.9T. I did the timing belt last summer. I did get a cam locking tool on Amazon for $20 - $30 I recall. This helps lock the cams to each other. However, if you are not careful, it can slip off or the crank can get out of time with the cams.
If you search a bunch of Volvo forums, you can find DIYs for the job. There are also Youtube videos for similar cars.
The job would be easy if the engine were out on a bench. The difficulty comes from the fact that you have to reach down between the front of the engine and the right front wheel well. There isn't much room. I replaced my water pump, tensioner & idler pulley at the same time. I took my time and it took the better part of a day. Getting the belt tension correct with the temperature dependent marker is a bit tricky as well.
If you study it, plan it & take your time, it's not too bad of a job.
He may have been looking at the Volvo rear cam locking tools. The one from Volvo is pricey, Ive seen them for $350 or so online. You can get an aftermarket one for $100. And you only need the REAR lock if you have to pull one of the gears off... and that leads me to an issue with S40's. The VVT gears start leaking oil sometime after 100k.
How many miles on the car? Have you pulled the upper TB cover off to take a look at the belt? If not pull the cover asap and check for any oil on the belt, gears or the inside of the cover. If you have oil either your VVT gear is leaking and needs to be replaced and/or an oil seal is leaking. Either way a gear will most probably have to come off and you, or your mechanic, will have to buy the rear cam lock tool.
If everything is dry, and you dont want to mess around with the VVT gear or oil seals, a cheapy cam lock will do. You can even make your own from a block of wood pretty easily. the internets has many examples of this
If the car has never had the TB done then the marks on the gears should line up with the notches on the TB cover. You can pull the crankshaft pulley or leave it in. I left mine in and had very little trouble with it. There is a mark on the inside of the crankshaft gear and a mark on the oil pump housing, both visible from above. You do have to fiddle with the belt to get it back on. I didn't have an impact wrench back then, I do now... and if I had it to do again I would pull the pulley and replace the seal while I was at it. So if you have access to an impact wrench I would do it.
Let us know how it goes!
I didn't replace my cam seals. I hope I don't regret it. Also, I didn't remove the crank pulley. It isn't too bad to fit the belt over the pulley in place. I don't have any special tools or impact wrenches either.
There is a stud in the block that holds the engine mount to the block. As I recall, it is necessary to get the stud out of the block. I think you have to "double-nut" it to remove. If not, you cannot get the engine mount out of the car. Also, installing the new water pump can be pretty hard to reach.
I ended up buying the $80 rear cam locking tool from amazon AND ended up having to go back in there to replace my vvt gear a month AFTER having done the seals. The rear cam locking tool + the crank locking pin does make the job more lengthy BUT 1) you will know that you have nailed the timing and 2) you will be prepared when your vvt gear finally goes...mine went at 130,000 miles.
And if you do the VVT gear, you may has well do the cam seals too... none of mine were leaking yet, but half of them had oil sitting around them. Forget Volvo prices for the seals, I found SKF seals (SKF makes the seals for Volvo) for 6-$7 from an online store. I have all of the SKF part numbers written down somewhere if you need them.
#18
Actually, I would greatly appreciate it if you could send me the part numbers. I ordered a new Timing belt online, but they sent me the wrong belt (i.e., it was too long). Of course, I did not know that until I had all the stuff in the way and the Engine Mount removed!!! Thanks in advance.
-Atch
-Atch
#19
#20
