2002 s40 motor mount
Old 12-03-2016, 03:05 PM
mrford55's Avatar
Default 2002 s40 motor mount
i think i have a bad motor mount. left upper. mostly when car is cold . drive away slow left wheel turned.feels like motor mount is bad. sounds like something touching the frame. you can feel the engine in the frame coming and going.just checking if any body had motor mount problems on a s40.some times driving step on the gas hard it goes away.let off on gas comes back.
Old 12-03-2016, 05:00 PM
Not all that uncommon. you can search the board for some other threads with pics.
Old 12-10-2016, 09:23 AM
mf70's Avatar
Old 12-16-2016, 06:39 AM
Hudini's Avatar
There are 4 mounts. Two main ones on top, two small ones on bottom.
On my 2001 you could feel the vibration through the brake pedal with the car idling and in gear. I replaced all 4 but after inspection only the bottom 2 were cracked.
Be careful if you change the main mount (right side as you are sitting in drivers seat). Volvo changed the mounting arm too so it's an extra expense. The left side trans mount on mine was perfect and didn't need to be changed.
Bikeartatx
04-20-2014 08:29 PM
srussell39
05-03-2012 07:02 AM
tuner4life
04-27-2012 06:41 PM
phonostudio
05-02-2005 08:59 PM
hispanic panic
01-14-2005 07:59 PM
Quick Reply: 2002 s40 motor mount
