2004 S40 Airbag light is on
Old 06-10-2010, 09:13 PM
bc9ltjj's Avatar
Default 2004 S40 Airbag light is on
A steady airbag light (red) is on after I plopped a book bag weighing about 20 LBS on the front passenger seat. As someone suggested I removed the battery and reconnected while the ignition key is on II position. But did not work. Did I do it right? Should I have waited for a while? I even disconnected and reconnected every plug under the passenger seat. Dealer said it need to be reset by a computer. It will cost me $167 to diagnose plus any work is required (Ouch!). Is there any cheaper way to correct this problem? What does the light mean? Will the airbag be deployed in case of a collision? Dealer said it won't but I am a little skeptical. Any suggestions? Thank you for your help.
Old 06-11-2010, 06:40 AM
SVTfocusO3's Avatar
It more than likely has to do with the OWS (occupant weight sensor). try a full network reset by removing both terminals and touching them together for 15 min.
Old 06-12-2010, 12:08 PM
bc9ltjj's Avatar
Dear SVTfocus03,
It did not work, unfortunately. I disconnected the battery cables from the battery and connected the two cables for 15 minutes as you suggested. When I turned on the engine, the light flashed once and stayed on. Any other suggestions would be appreciated. Thanks.
Old 06-13-2010, 12:06 AM
SVTfocusO3's Avatar
You should get it scanned. sorry.
Old 06-13-2010, 11:23 AM
bc9ltjj's Avatar
Thanks, I guess I will have to spend money. But until then, what is the consequence? Is airbag disabled?
Old 06-13-2010, 08:22 PM
SVTfocusO3's Avatar
Let me ask you this, is this a 2004.5 or the older body???
Old 06-14-2010, 07:11 AM
bc9ltjj's Avatar
It is a 2004 model.
Old 06-16-2010, 12:30 AM
robbinhood's Avatar
The S40 dyno is kinda hard to interpret as there is no stock S40 dyno given and the 2 tests shown were on disimilar octane fuels and exhaust mods.Besides on the dyno charts for the S40, has anyone seen ipd list an estimated increase in TQ for any of the volvo models? Their website says nothing about what kinda numbers they got on any of the volvos..Let hope they give stock vs stage 1 dynos using the same octane fuel for comparison.
Old 06-16-2010, 12:32 AM
GerBeGurGya's Avatar
Dude are you on crack?This is your 2nd post and both of them are nonsense.
Old 06-16-2010, 03:58 AM
jemsbowen's Avatar
The S40 is a bit difficult to interpret because there is no S40 Dyno given stock and the two samples were presented octane and exhaust mods disimilar. I stopped taking them seriously, and I am at the end of my wits to get the problem fixed anywhere - and that is why I am here. What do you suggest is the problem with the room air bag light, and how do I know it is fixed rather than someone just turn the warning light off. " I do not trust my local service at this time.
atlantadriver
04-26-2021 08:25 PM
nigel_miguel
11-25-2012 08:21 AM
Alyssa25
07-13-2012 11:38 PM
john5000
05-05-2010 11:08 AM
VBsportbiker
03-25-2008 01:32 PM
Quick Reply: 2004 S40 Airbag light is on
