2006 Headlight Bulb Replacement
RE: 2006 Headlight Bulb Replacement
Well it turned out ok. She got here this morning, pulled into the driveway, the light came on. She said the warning light on the dash would come on and off. Said leave it alone. Took it to the dealer for the state inspection and told them about it. They repaired the connection, and put in a new bulb. All for free, warranty. Inspected it for free also. I suspect the connection was loose, they added dielectric grease and a new bulb. Thanks again, Tom
2004.5 S40 Low Beam
Has anyone ever replaced the passenger side H11 low beam on a 2004.5 or 2005 S40? I bought the bulb and I can see where the cover is, but the power steering fill cup is in the way. Do I need to remove that? Is there a trick to pull the head light assembly out? Any assistance will be appreciated.
thanks,
thanks,
Volvo was very clever with these. The entire headlight capsule removes. If you look under the hood at the top of the light you should see a metal that you pull up and remove. Then the headlight capsule slide completely out.
It is in your owner's manual if you have one. If not:
https://www.customers.volvocars.com/...0/04s40_00.htm
Stan
Stan
TrusWeld
04-28-2010 07:05 PM
