2004 S40 T5 Turbo Air leak
Old 04-27-2010, 11:43 PM
Wikiwiki1's Avatar
Default 2004 S40 T5 Turbo Air leak
My check engine light came on so I read the codes. It reads "P2281 Air Leak Between MAF and Throttle Body" and "P2187 System too Lean At Idle". I can't seem to find a service manual for this thing can anyone
get me going in the right direction to find the leak? I looked around and don't see any broken/cracked hoses however I'm not very savy on where all the parts are at that may cause this.
Thanks, Brent
Old 10-27-2010, 03:02 PM
Sandy0709's Avatar
Default System too lean at idle
Brent,
Did you ever discover the problem with your car? I have a 2005 S40 T5 and I'm getting the same code (system too lean at idle 1st stage). I've seen no change in performance, but it makes me concerned to have a recurring check engine light, even after being cleared a few times. Sorry I don't have any advice/help, but I'd appreciate hearing how things have gone with your car. Thanks.
-Sandy
Old 10-28-2010, 08:47 AM
Wikiwiki1's Avatar
Sandy, I took all the hoses apart and made sure there were no leaks and the air flow sensor was clean. Then made sure the connections were secure. Then i reset the check engine light and the message didn't
come back.
xcyx
04-11-2018 08:47 PM
volvoDT
07-23-2010 03:28 PM
jihae84
05-01-2010 10:21 PM
rquinonez32
09-30-2008 02:08 PM
austeve
07-29-2008 09:08 PM
Quick Reply: 2004 S40 T5 Turbo Air leak
