airbag light
Old 08-09-2005, 10:17 PM
nandrolone's Avatar
Default airbag light
My airbag light is staying on. What do I do to fix this?
Old 08-13-2005, 12:59 PM
nandrolone's Avatar
Default RE: airbag light
Tech?
Old 08-14-2005, 12:43 PM
You need to have the codes pulled so you know where to start looking for the fault.
Old 08-26-2005, 11:36 PM
nandrolone's Avatar
I had the codes pulled and I need the airbag clock spring. Anyone know how much it costs?
Old 08-26-2005, 11:57 PM
I forget exactly but I think it is pretty expensive.
Are you going to replace it?
Old 08-27-2005, 12:04 AM
nandrolone's Avatar
Yeah, I have to replace it to get it inspected. I have a machanic that said the labor will be about $125. He said he has to pull the steering wheel off. Is there a way around this? I was told I can only buy this part at volvo. Any advise?
Old 08-27-2005, 12:12 AM
I think you can only buy it from Volvo and yes you have to remove the steering wheel to replace it.
It sits behind the steering wheel.It also controls the connections for the horn.
Old 08-27-2005, 02:40 PM
and the mechanic have to be exact to center the steering wheel with the clock spring.
Old 08-27-2005, 03:30 PM
ORIGINAL: Red XC
When they come new they are locked into center.It is just install and then install the wheel then remove the screw and you are good to go.
Old 10-06-2005, 01:51 AM
nandrolone's Avatar
Had the dealer pull the codes. They said a sensor got wet and reset it. No problem since!
Old 01-08-2009, 07:00 PM
snkpkp's Avatar
My horn and other audio buttons died so I assume its the clock spring in my 2001 S80. However I got the AIRBAG SERVICE msg now , so when I replace the clock spring with new one, will the AIR BAG ERROR MSG go away in a few cycles ?
Old 01-08-2009, 07:01 PM
You will need to have it cleared.
Old 01-08-2009, 08:26 PM
snkpkp's Avatar
volvo just closed its dealers in Bangladesh, so I guess I am on my own on this one
atlantadriver
04-26-2021 08:25 PM
VBsportbiker
03-25-2008 01:32 PM
donald1
11-08-2006 08:38 PM
auburnvolvo
06-05-2006 02:19 PM
2003bhoy
11-20-2005 01:38 AM
Quick Reply: airbag light
