07-29-2009, 05:47 PM
airbag light
went to the dealship today volvo ,,to see why the airbag light
costed 118 to look at it which came to 133 with taxes
code cdoe srs-0137 sips bag inactive
requires right side sips bag $908 with taxes
ouch
how can this happen,,
anyone with this kind of problem before?
will be checking other places for estimate
also with this problem,,will my driver side airbags work
thoughts
07-29-2009, 08:42 PM
what year car is this.... this sounds like something volvo should cover.........
__________________
94' volvo 850 wagon non-turbo automatic - burgundy
94' volvo 850 wagon non-turbo manual - silver
00' volvo s40 sedan turbo automatic - sliver
if the brakes didnt squeal it wouldnt be a volvo...
07-29-2009, 08:45 PM
Moderator
I know that your SIPS system has to be scanned every so often. My car has a sticker on the side of the last inspection. What year and model are we talking about?
07-29-2009, 09:03 PM
response
2002 s40
121000 kms
07-29-2009, 09:13 PM
Moderator
Hmm..Don't quote me on this but I wanna say the air bags might be covered for 10 yrs.... I am not certain, but If I were you email Volvo USA and see what the response is.
07-29-2009, 10:27 PM
response
from canada
not covered here
07-29-2009, 11:50 PM
i think the Canada is also covered.... dont quote me on that though.
worth a check before you spend $800000
__________________
07-30-2009, 12:25 PM
response
checked withe dealer and also called volvo canada
and it is 5 years on the warranty
darn...was thinking maybe a loose wire..just hate paying that price where obviously never used airbag....also if this saide airbag does not work,,will the other air bag work
thanks
07-30-2009, 12:46 PM
yes. what you can do is remove the plug on the air bag and jump it with a paper clip or wire and the srs light will go out.
__________________
07-30-2009, 05:48 PM
first of all..on that jumper wire you need about 2.5-2.9 ohms resistance, then will the airbag light reset on it's own ummm! when the airbag light is on usually the whole system is disabled. might want to go see a local volvo mecanic, because here in canada volvo de3alers seem only want to replace parts instead of inspecting the actual problem.
Tags
0137, 2002, 40, air, airbag, bag, code, flashes, forum, light, replace, s40, sips, srs, volvo  |
| Thread Tools |
Search this Thread |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
