cam shaft actuator repair
#21
I bought a Stant 48639 thermostat which turned out to be a Wahler thermostat made in Germany in a Stant box.
#23
My local indy shop wanted $1200 for just the timing belt replace, not that I took them up on it. I don't think they wanted the job.
Did the shop have a Volvo Dice VIDA scanner? If not, you may want to set one up yourself. There may be some Volvo codes lurking in the ECM that would set you on the right track for the low power problem.
#24
Thanks for the tips everyone... you've all been very helpful in fixing this problem.
The CEL turned off yesterday... as soon as I changed the thermostat it seems that the power increased... maybe this was just perceived... I don't know. The new gas seems to have helped too.
Of course I've just ordered $100 worth of parts (radiator temp sensor, air filter, and boost solenoid)! Oh well... I'll probably replace them all just to put the new parts on - preventative maintenance.
#25
MoneypitC70
2001-2013 model year XC70
10-26-2014 08:37 PM
Volvo-Profess
01-14-2011 05:55 PM
