check engine codes
Old 11-21-2013, 10:16 PM
Newport_j's Avatar
Default check engine codes
i just got a reading on my 2002 Volvo s40 when my check engine ligh came on a few days ago. The codes are as follows:
P0705
P0444
P0700.
What are they in a 2002 Volvo s40? I have looked on the internet and the first and third (P0705 and P0700) have to do with the transmission, but the middle one P0444 I just do not know what that is.
Any help appreciated. Thanks in advance.
Respectfully,
Newport_j
Old 11-22-2013, 12:10 AM
Hudini's Avatar
Google says P0444 is an evaporative emissions system problem. Further reading says it's probably not a bad gas cap, more likely a purge valve or Volvo equivalent. Anyone else experience this code?
Old 11-23-2013, 04:11 PM
Newport_j's Avatar
Default Evaporative Emission Control System Purge Control Valve
The check engine code for P0444 is explicitly the following:
evaporative emission control system purge control open open
Now on a 2002 Volvo s40 where is this valve located? How do I check for it to be open? Is it not easier to just replace it?
Respectfully,
Newport_j
Old 11-24-2013, 08:35 AM
Disco2's Avatar
As you're facing the car, it's on the top-right of the radiator, just to the left of the battery. Don't know how you test it. Here's a link for the part: Volvo EVAP Vapor Canister Purge Valve - Pierburg 9470775 | FCP Euro
wieder
09-10-2010 08:42 PM
gabyman97596
05-14-2007 09:52 PM
cranky
08-05-2005 09:46 PM
Quick Reply: check engine codes
