Door stop driver side door
My driver side door gives a metallic crumpling sound when it is fully extended. ; it only started happening recently. I was told by a mechanic that the doorstop need replacing.
I have a 2002 Volvo s40. What is the part name and number and is it hard to replace?
Again this is the driver side door.
Thanks in advance.
Newport_j
Thanks in advance.
Newport_j
Have similar Door Stop Problem 2000 S70
Yah, I didn't even know what to call the part...Is it expensive ??..
It allows the door to open half-way to keep from denting adjacent parked cars, and then fully open...
Looks like a ball-joint knuckle into the door post; guessing the inside door cover needs removed....what mysteries/nightmares await ??
Replace Window Regulator/Motor while we're in there ???
Any One ???
Any One ???
Check with Tascaparts.com.
Heh, Tasca thinks a 30652143 is a wheel arch molding. I picked up the pic from
http://www.volvopartswebstore.com/im.../GR-368885.jpg
so I would guess Volvo Parts - Authentic OEM Volvo Parts direct from Volvo Parts Webstore | VolvoPartsWebstore.com would have the part. Around $46. This would be a good junker part, if they want less for it.
Markvolvo
12-29-2013 01:23 PM
