ECM 640A camshaft reset valve fault signal
One of the cam gears being off a tooth could cause it. It's telling you that even with the cam fully advance or retarded that it is still too far out of adjustment. A clogged CVVT solenoid can also cause it. The clogged passages are not allowing the cam to move as commanded by the engine's computer.
Are you familiar with Continuous Variable Valve Timing? I posted a pic in your other thread showing the CVVT gear hub. The pic is from a 2001 model but the newer ones are similar.
I mentioned to teh dealer about the solenoid (I replaced the solenoid last year; the one with part number 36002687). I mentioned that the solenoid prob needed to be cleaned. But he said that with the computer they can control the solenoid and found no problem with it.
They replaced the timing belt so I also mentioned that it could be one tooth off but he said they checked it. So he said the VVT actuator (sprocket) needed to be changed since that's the only thing they can think of that's causing the check engine at this point since this code was stored in the system and they turned it off and after about 5 minutes driving, it came back.
So what's a sprocket??
So time for another camshaft intake valve.
Would that cause my fuel mileage to decrease? I have seen a higher than normal gas consumption since I had this code.
Unfortunately the dealer who fixed my car in about 2 hours away and for a part costing $119, he would probably charge me 1 hour to install so another $210. These valves can be changes in 15-20 minutes and I know that for a fact. But of course what do we simple people know? They know it all better than us right?
frknvgn
2001-2013 model year V70
08-27-2015 07:28 AM
dejan_da_dude
02-24-2015 01:17 AM
