Error code PO335 & PO341 2001 S40 - Volvo Forums - Volvo Enthusiasts Forum
Thread Tools Search this Thread
Old 03-14-2009, 05:02 PM
Unhappy Error code PO335 & PO341 2001 S40
I have a 2001 S40 that had a head gasket replaced. The check engine and oil pressure light came on and had the following error codes:
1. PO 335 MOD $13 10F2 Crankshaft position sensor `A` circuit malfunction.
2. PO 341 MOD $13 Camshaft position sensor `A` Bank 1 CKT range /perf
I have changed 2 sets of spark plugs and the plugs get darkened and had gasoline on it after a couple of starts. The car shakes when stop at an uphill position.
Please help!!!!
Old 03-15-2009, 11:04 AM
rupert77's Avatar
these codes will come up if there is bad fuel pressure, maybe it is the fuel pressure regulator is defective. Cannot see the two sensors been faulty it is a bit of a coincidence. If your crankshaft sensor was faulty your car will not start sometimes!?! Does it? I have looked up somwhere before on the net about these codes been pulled and they will come up for a number of reasons but cant remember them only the fuel pressure theory!!! Take your oil cap off after a run and see if the oil smells of gasoline if so it may well very be the FPR.as above. Hope this helps let me know.
Old 03-16-2009, 03:39 AM
Hello Rupert,
Just when I thought all is not well with me, your reply is like a heaven sent.
I will give it a shot and will keep you posted. Thanks a bunch!!! It is very very much appreciated.
Old 03-23-2009, 02:16 AM
Default From Frying Pan to Fire!!
With refrence to previous problems, the mechanics took the top part of the engine and reasemble it and now the car would not start.
He says that it was due to the cam shaft allignments.
Could anyone relate to how to alligned the top dead center for the crank and camshaft position mode ?
According to him there may be a special tools that are required.
Please help.....Thanks
Old 03-23-2009, 08:25 PM
Yes special tools are needed. You will need to lock the cams to set it all up.
Thread Thread Starter Forum Replies Last Post
SRS Airbag Urgent Service & error code 025 - will my airbages deploy? djannrae 2001-2013 model year XC70 1 10-09-2015 09:32 AM
Cam position sensor s40t code po341 Bobby B769 Volvo S40 1 07-17-2015 07:43 AM
2002 S40 PO341 no start Dragonhawk Volvo S40 4 02-26-2015 12:34 AM
2001 Volvo S80 T6 - P1175 & P1185 Error Codes milbro40 Volvo S80 0 07-26-2011 10:45 PM
CD Changer Error Msg - "Deck Error" khesser Volvo C70 1 07-02-2007 12:37 PM
Tags
13, 2001, camshaft, code, crankshaft, find, po335, po341, position, positioning, s40, s70, sensor, tdc, v4, volvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
