Firestone broke my key. Please help
Hi all,
I have a 2000 S40 and I went into Firestone for a routine battery change. They ended up snapping my key in half while putting it in the ignition. Eventually they got a locksmith to get it out. I got my key glued together by a mechanic, but it doesn't work perfectly anymore and I have to jiggle it for a few minutes before I can get it to start.
Anyway, I'm sure I could get a lawsuit filed, but I'm a broke grad student so I don't have the time or the money.
My question is: what is the cheapest and easiest way to get a new key? I don't have a spare and the dealership said it would cost $300 for a new key! Surely there is a better way. It doesn't have a chip in it but I've been told that it can't be cut by a locksmith because it needs programming. I still don't understand why that is the case.
Any advice would be lovely, thank you!
Hi all,
Firestone claimed there was a crack in my key and that's why it broke. There was a small crack, but it was totally fine when I was using it. I don't think they'll admit it was their fault.
check out 2000 - 2004 Volvo S40 V40 Master Transponder Key OEM
You can call around for an automotive locksmith to see if they can cut/code a master blank.
dawagner93
04-28-2015 07:21 AM
thegazelle
08-05-2014 04:47 PM
volvoQ's
06-12-2010 07:00 PM
