B4204T engine spec
Old 01-14-2014, 08:35 AM
mams's Avatar
Question B4204T engine spec
hi guys,
I need your advice on the engine spec. before this my V40 2004 phase 2.5 2.0 T use engine B4204T3.and now i replace to new engine is B4204T engine no (2854214) , and this new engine have VVT. what the engine spec for T? ist T,T2,T3,T4 or T5? please help
Old 01-14-2014, 04:36 PM
difflock54's Avatar
Found this from a post in another forum.
It may help you?
To carry on from Gmain's post... as a rule of thumb the early phase 1 T4 had the 1855cc unit with the phase 2 having the 1948cc unit, both T4 engines producing 200bhp/147Kw.
Phase I
1998 - B4194T = 1855cc (high pressure turbo)
1999 to 2000 - B4194T2 = 1855cc (hpt)
1998 to 2000 - B4204T 1948cc (low pressure turbo)
Phase II
2001 to 2003 - B4204T5 = 1948cc (hpt)
2001 to 2003 - B4204T3 = 1948cc (lpt)
Old 01-17-2014, 12:15 AM
mams's Avatar
Question
It may help you?
Phase I
Phase II
hi guys,
question on phase I model 1998-2000 B4204T 1948cc have use VVT?
Old 09-18-2017, 11:20 AM
willbr's Avatar
I bought a repoed 2000 V40 (build date 9/1999) from a tow company & the block is stamped with B4204T. It has the overheat buttons & yellow paint markings on it so Im sure the engine has been replaced. It does have exhaust cam VVT. Not knowing the history of the car I cant say if it originally came with a B40204T engine. If the car did not come with VVT then the computer would not know what to do with it. I did notice while doing the timing belt that the VVT gear does not move like Ive seen in the videos.
Old 09-19-2017, 06:51 PM
pretty sure all US shipped 2000s have the VVT (and yes its only on the exhaust cam) - some were built in 1999, best way to check is to look at the block serial number (should be on the exhaust side of the engine by #1 cylinder...
cb1313
05-23-2009 11:49 AM
lata
03-20-2008 03:45 AM
crispyshreddedbeef
06-12-2006 09:29 AM
reriver
09-01-2005 10:15 AM
mr
03-31-2005 12:16 PM
Quick Reply: B4204T engine spec
