fuel problem???
fuel problem???
Hello I have a 2005 s40 non turbo with a cel and code P0189 and P0192
so I changed the fuel rail pressure sensor and they went away and now P0089 comes up and CEL again?? Also now I have a sound I,ve not heard before which seems to be coming from the fuel tank area!! Is that where the fuel pressure regulator is located? or could I have messed something up changing sensor?
Thanks
Thanks
ENGINE-CODES* OBDII CODE LIST* P0089 VOLVO
P0089 VOLVO
P0089 VOLVO - Fuel Pressure Regulator 1 Performance
Possible causes
- Fuel pressure sensor harness is open or shorted
- Fuel pressure sensor electrical circuit poor connection
- Faulty fuel pump
- Fuel line restricted
- Faulty fuel pressure regulator
- Faulty fuel pressure sensor
That's what that code means and I'm going to bet that it's the fuel pressure regulator....
Get a fuel press regulator and an o2 sensor and you will have no probs.... Then clear your codes at an advanced auto parts and i bet it won't come back.
P0089 VOLVO
Possible causes
- Faulty fuel pump
thank you I replaced the sensor and the codes pertaining to that went away but I'm going to check wires and connection to the sensor again I doubt anything there but you never Know I hope it was a good part!! this forum is a huge help thanks again
I have not found a part # for a fpr on 3 volvo parts sites for this car called Tasca and they don't show that there is one for this car. It must be on the pump in the tank!!
orcutd
09-27-2008 08:13 PM
the_happy_driver
06-26-2008 12:47 AM
