headlight bulb replacement 2002 s40
RE: headlight bulb replacement 2002 s40
From the back side under the hood on teh back of the light is rubber caps over the holes. Remove the rubber cap then unplug the bulb. Then unhook the metal tab and slide the bulb out.
Becareful the plastic in the mountings break alot and then the headlight flops around.Also the plastic on the plug falls apart as well.
Did you enter the code wrong 3 times?
If not stop by local Dealer and get the Radio code they should give it for Free.
Then you will need to input it into the radio for it to work.
Also slide the radio out and make sure no one wrote it on the sticker already.
The daughter inlaw punched in random codes,,which put it in off mode....contacted a volvo dealer and got the correct code. Had to turn key in first position,,wait two hours until radio said "enter code"....input the correct code and all is well.....thanks for the help.....Paul
Kiss4aFrog
01-19-2012 12:54 PM
