high pitched squealing noise coming from belts ? - Volvo Forums - Volvo Enthusiasts Forum
LinkBack Thread Tools Search this Thread
Old 05-15-2011, 09:29 PM
Default high pitched squealing noise coming from belts ?
My S40 started squealing near the alternator area, it hesitates when you take of from a stop and sometimes goes quiet for the first 5 minutes of driving. The belts look tight was told a pulley may need grease? Should I replace the belts ? A mechanic told me you have to remove the front quarter panel to do that wow!
Old 05-17-2011, 02:08 AM
Default one or
one or two things,
1.the belt maybe loose
2. your water pump is going, there's a little hole on the water pump. That starts to leak just before it going. It let water out and it gets on the belts. And squeals until it's dirt.
Old 05-18-2011, 09:34 PM
Okay I know this might sound odd but my 2003 S40 was doing the same thing at startup and it turned out to be a missing nut on the exhaust manifold. Now that is a bit out there I know but it takes about five minutes to check all of those nuts on the exhaust manifold by removing the heat shield on the back of the engine. It's worth the trouble and it solved two problems on my car: squealing at startup and noise from the manifold. Next thing to note you can replace the one serpentine belt with a new one. You will need a Torx bit and a breaker bar but no removal of fenders.
Old 05-23-2011, 02:46 PM
had this on mine changed the alternator has know shut up it was the bearing that the belt go's on had moved in see if it moves in and out and if there is any silver dust about cuz mine was rubbing on its case
Old 05-31-2011, 09:28 PM
ANy luck on this? i may be having the same sound, doesnt start until about 5-10 min of driving...loud squirling, a very good friend/mechanic said he thinks its the Ac compressor, so i picked up 1, gonna replace it and see what happens, we tried the long screwdriver technique on the alternator and he said he was almost certain it was not coming from their, but damn its very annoying whatever it is...and my belt is fairly new....so deff not that, let me know what the scoop was if u get it fixed
Old 06-01-2011, 11:29 AM
When the same thing happened to my old 440 my local non franchised Volvo shop put talcum powder on the belt and it stopped the noise, of course this would not work with a worn bearing or pulley wheel
Old 06-01-2011, 06:44 PM
No haven't done anything about it yet. Now floor behind driver seat keeps getting wet now . Check Enging light still on so dont drive it much if can help it. The AC is icy cold at times but will go to lukewarm so prob is the compressor.
Old 06-03-2011, 09:32 AM
Default noise! could maybe not the belts
I had the same noise.but not the belts!!.......If the sound goes away when you remove the `OIL Drip SticK`......( Feel feel also a Negatif pressure )..........The problem is that the `diaphram inside the oil filter housing ` is punctured.
requires a Filter Oil housing .
regards
Old 06-03-2011, 09:44 PM
just wanted to let you kow i had my car looked at again for the squeeling, they contacted a volvo mechanic up in the cities and the mechanic told him hes almost 100% certain theirs a valve that for some reason is creating a suction that is not supposed to be their....now this may be no help or some to you but....ill give you the exact details next week when i c the parts ordered but it wasnt cheap...the good news the volvo mechanic said its a very common issue, when they get the parts and the fix done ill be able to give ya the run down...maybe something you can have checked out....l8r
Old 06-03-2011, 09:46 PM
i shoulda read above me.........thats my exact problem as well the exact thing!!
Old 06-03-2011, 09:49 PM
Car Parts Wholesale=
this little bastard!! damn it causes quite the annoying little sound
Old 06-04-2011, 08:28 PM
Cool.........
Regards
Merci,
Old 06-05-2011, 11:22 AM
has your car got a sun roof and is the water coming out of what appears to be the rear heating vent under the front seat, if that the prob I know how to fix it in 20 minutes
Old 06-05-2011, 10:42 PM
Default water on floor behind driver seat
Yes my 2004.5 2.4i does have a sunroof.
Old 06-05-2011, 10:45 PM
Yes E13 my 2004.5 2.4i does have a sunroof.
Old 06-10-2011, 08:14 PM
did you get my reply about the water in the rear floor well I cant see it it ???
  #17
Old 06-10-2011, 09:11 PM
Default 02 s40 engine noise
Hey same thing was happening on my s40 2005 it was makeing the same noise and when you remove the dip stick or oil cap the noise would go away ,call the volvo dealer , and they informded me that ther is a recall on the egr regulator, so they replaced it and no noise .
Hope this helps
  #18
Old 06-14-2011, 06:14 AM
Cool!!....commun problem...the `diaphram`inside the oil filter housing punctures...!!!..housing assy replacement.
regards
Thread Thread Starter Forum Replies Last Post
960 1997 high pitched occasional noise coming from engine Steveppod Volvo 260, 760 & 960 12 09-07-2013 09:02 AM
88 740 high pitched sequel coming from under the parking break lever 92_240_sedan Volvo 240, 740 & 940 1 02-16-2013 01:47 AM
Pls help,S40 high pitched squealing noise M363P Volvo S40 6 09-30-2011 09:15 AM
Intermittent, high-pitched squealing/whisting noise from my 1999 S70 99s7o Volvo S70 1 03-17-2011 09:55 PM
Squealing belts...but is it the belts? rcoonce Volvo 240, 740 & 940 6 12-02-2007 10:51 AM
Tags
240, 40, belt, car, coming, fan, high, noise, pitched, s40, sqeealing, squeal, squealing, tight, volvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
